Bolt threads
Jerryh3
Is there a NPT equivalent for a .500-13 UNC? Trying to rig up something for the Mercruiser drain plugs and need to do some shopping.
etracer68
Ensign
Re: Bolt threads
To answer your question, NO. A 1/2-13 is 13 threads per inch, the closest diameter would be a 1/4-18 NPT, and the missmatch on the threads per inch would be to much, besides a pipe thread is tapered. A 1/2-20 would be closer on threads per inch. Either way it should be drilled and tapped, and that may put chips in the LU. What are you trying to do?
Jerryh3
Re: Bolt threads
Replace the blue drain plugs with a thread to barb connector for a central drain/flushing setup.
NetDoc
Re: Bolt threads
What you want is a banjo bolt & fitting.
Fitting
Banjo Bolt
bruceb58
Re: Bolt threads
Whatever you rig up is going to get blocked with crud so you need to remove it anyway. I would stick with the standard plugs.
