Ok, I have researched until I'm blind, and there seemm to be two trains of thought..<br /><br />1: That you should epoxy bed the stringers to the hull to attach.. Then glass in place<br /><br />2: That you shouldn't bond, as flex needs to occur and two different materials will invariably flex at different rates..and crack therefore they should be placed and then fillet and glass.. basically a stitch and glue.<br /><br />There also seems to be diversion as to whether to use woven, mat and cloth, bi-axial tape, etc. <br /><br />All seem to refer to the fact that it's the glass encapsulation that creates the strength, and not the actual stringer itself. #2 appears to be the way Project Bilgeliner was built, not that that means anything. <br /><br />Opinions, thoughts.. assorted "you're crazy's" appreciated. <br /><br />Thanks!<br />Roger
