Bondo as filler?
P3FE
I have installed a new deck and need to cove the edges of the plywood to the hull before glassing- Is using bondo a good idea?
Woodonglass
Re: Bondo as filler?
Welcome to iBoats!
You could but... EXPENSIVE. Make your own.
here is the forumula from one of our PRO Members...OOPS
cabosil....glass bubbles and 1/4 inch glass fibers.....mixed with resin
mix it up REALLY well NO LUMPS!
after its mixed up good....then add the catalyst.....according to the amount of resin you added....between 1.5% to 2.5%...no more....no less
It should be the consistency of Mayonaise or Creamy Peanut butter.
www.uscomposites.com is a GREAT source for your materials
