edfishing2
- Joined
- Mar 6, 2011
- 144
83 Evinrude 100hp. I have all new Wisco pistons have the block bored and honed .044 over but the steel sleeve looks very thin on one side especally at the "splines" at the ports. Does anyone know what wall thickness (at this thinest splined area) is acceptable?
Does this "spline" go all the way up the OD of the cylinder sleeve walls or is it just the lower section of the original sleeve?
If too thin can this block be heated up and the old sleeve extracted. If bored to install new sleeve does the aluminum get too thin? Ie what is suggested max sleeve OD.
Does anyone know the diameter and spacing for the ports if I install new sleeve?
What is center to center distance on cylinders?
Thanks,
Ed
Thanks,
Ed
