Bottom cylinder won’t fire but still has spark
im not sure what’s going on but I’ve thought many things were wrong with my 1995 Johnson 120 but what I have finally found is that one cylinder won’t fire but it does get spark. You can take the plug wire off while running and it won’t change. We cleaned the carb that is in line with the cylinder but that didn’t fix it.
dwco5051
Do a compression check on all cylinders first and give us the numbers.
flyingscott
I believe that is an xblock looper. That means the portside cylinders use the starboard carbs and vice versa. I believe, if not somebody will be along to contradict me.
Agreed ----Look at the other lower carburetor.----These cross over.----Looking from front of boat the bottom right carburetor feeds the bottom left cylinder.
Alright I cleaned the other carb now when it is running I pull the plug and it hesitates the slightest bit so I’m hoping that fixed it. It still pops once warmed up but I’m hoping that’s just because it’s not getting back pressure from being in the water.
Make sure carburetors are free of restrictions.----No fuel going in also means no oil ??----Compression test results are ???
If a carburetor is plugged then one cylinder will be starved of oil.----Little bit of WD 40 won't help at all.
I’m hoping it’s good now I don’t think anything in the cylinder got damaged, spark plug in that cylinder also looks good too
