Bottom leak on fuel pump 1963 McCulloch 75hp
jimberg
I have been trying to chase down a fuel leak . So far have replaced all the pressure lines and have figured out that the leak is at the bottom of the fuel pump. Now I am stumped as to how is the best way to remove the pump so as I can attempt to continue with the repair.
Hope someone here has worked on one of these and can help me out.
Thanks
jim
steelespike
Re: Bottom leak on fuel pump 1963 McCulloch 75hp
You might try the scott guy at ask the scott guy.
I used google and ask the scott guy as written.
Looks pretty straight forward in my after market manual.
4 hoses 2 gas in gas out.2 pressure hoses to crankcase.
When replacing hoses proper length is important. first stage is 13 to 13 1/4 inches,second stage is 5 7/8 to 6 1/8.older pumps use reed check valves between the 2 fuel chambers late models use disc type valves.
Its possible the scott guy may have a suggestion for pump replacement.
jimberg
Many Thanks for the info. and your takeing the time to post it.
I have emailed the contact.
Jim
jimberg
Forgot to say..that on closer inspection the leak is at the small plate at bottom rightside of crank case.
Should have looked closer before I posted.
