Re: Bottom Paint-Anti Fouling alternative
Interlux Micron 66 is good stuff, as is Pettits Trinidad SR. Both are neck-n-neck in Powerboat Reports ongoing evaluation of bottom paint performance, neither is better than the other. Fwiw, they are beating out a crowd of about 54 different bottom coats that are part of the evaluation. The Micron 66 ($194/gal) contains 40.41% copper. The Trinidad ($154/gal) contains a whopping 70% copper. Both have slime-resistant additive, hence the SR in the name of the Pettit product.<br /><br />The nasty stuff you are referring to is called TBT. It was removed from all bottom paint about 3-years ago
actually removed from all paints. It is really good stuff to inhibit mold, fungus growth in damp places (bathrooms, steam rooms) but very toxic for the environment. TBT is still available with a permit, and can be mixed into bottom paint, but the whole process of buying it, mixing it, and applying must be overseen by a licensed specialist. Its basically cost prohibitive to do. In my area, commercial fishing boats are still being painted with TBT laced bottom coat, as was my boat two years ago.<br /><br />Couple things to keep in mind, if you go with colored bottom paint, not all hold up well. Black is still king of performance in bottom paints, but it is not always necessary. Since your boat will be out of the water most of the time I doubt you will have issues with any color of bottom paint you choose.<br /><br />The other thing to know is that Interlux Micro 66 is NOT intended for use in fresh water. It is intended for a boat that will be used only in the ocean.<br /><br />PBRs ongoing testing of bottom paints has been in the works for about 10-years. They paint one side of two identical panels. One panel goes into the ocean in Connecticut, the other in Florida. The Connecticut panels never do as well as the Florida panels, i.e. different marine biology. So the folks in Florida get a little more choice in bottom coats that perform well. Being in Mass, you may want to stick with either of the two paints mentioned above. Personally, I think there is enough dollar difference between the two paints to influence any decision on which I would use.
