Bottom paint for trailer boat
Lake time
I have a 1985 carver montego 2657. We bought it in April and the bottom has antifoulin bottom paint. It used to be wet dock all every year up to no I have no plans or nor do I want to every dock it is the address bottom paint I can use that won't rub on my bunks
If your boat was done correctly it will have barrier coat and then some kind of ablative bottom paint. The only way to keep ablative paint from coming off is to remove it. This what the paint is designed to do in the water on it's own.
If you make it down to the gelcoat it could have fresh gelcoat applied. Otherwise I would suggest removing the bottom paint and then repaint with epoxy
Lake time
Was not done correctly from what I saw and what epoxy would be best if need it in black if you have any good brands
Is black the hull color, or are you trying to cover the bottom paint.
because of the ablative properties of bottom paint, you need to remove it down to gel coat to paint with epoxy.
Sherman Williams makes some stuff called Marcopoxy which I like. Other brands would be Interlux and Pettit
Lake time
The boat is white and black I plan on taking the old paint off to smooth it out is layered bad we are talking at least 1/4 inch in spots the site won't let me post a picture
Try this to post pics, but if they are to large a file use something like photobucket
jbcurt00
I can post photobucket pix from my phone.
Are you on a windows, droid or apple phone?
dingbat
I used bottomcoat ACT on my trailered boat. Can be applied over most other paints and last multiple seasons w/o touch up.
jbcurt00
Try going to their site using the browser instead of the app.
There should be a SHARE button at the bottom of each pix
Clicking SHARE brings up a menu w Get Links
Click Get Links
That brings up a list of copyable codes
Copy and paste the IMG code for the pix you want to post:
