Bottom Paint Removal - Dumond Chemicals
Solittle
I have a 15 year old 23' CC that has the original blue anti fouling bottom paint on it and it looks like nasty. About 30% of it is wore off and I want it gone. I have read many of the posts on what to do. I ran accross a product that is advertised as "the best solution." <br /><br />The product is called Peel Away Safety Strip. They claim that it will remove up to 10 layers of bottom paint without damaging the gel coat with one application and is guaranteed. I called them and was advised that three gallons should do my boat. At $60.00 a gallon I would like to know if anyone has used this stuff & what their results were. Their web site is:<br /><br /> http://www.dumondchemicals.com/html/products.htm <br /><br />Some years ago I started to remove the paint on the sides (nasty job - I never finished). The gel coat underneath the paint did not look like it had been sanded before painting. If I go ahead with this Dumond stuff will I need to repaint or put any type of new coating on the bottom? I keep the boat on a trailer or rack at a marina and do not have need for anti fouling protection.<br /><br />Howard
flashback
Re: Bottom Paint Removal - Dumond Chemicals
Yep it works fairly well, you put it on, cover with special paper or wax paper and let it set over nite. then come back the next morning and start scraping. main thing is to let it on long enough to do its job but not long enough to dry out. (the reason for the paper is to keep it from drying out). it's a messy job not much fun but better than sanding ..........good luck
Solittle
flashback - Did it remove all of the old paint & with with one application? Some of the solutions I've tried get some, but not all, off and you have to keep doing it over and over.
Dead Eye
Is getting a pro to sand blast the bottom worth it or a risk to the gelcoat?<br /> Dead Eye
Solittle
No sand blasting for me. I have seen the pitting that sand blasting can do.
Formula1974
good idea dead eye has anyone ever sandblasted the old stuff off before?
