bottom paint
22ft bowrider lake boat, want to repaint the bottom, any suggestions in what i need? What i should avoid?
sasto
Re: bottom paint
Hi Stewart. What type of paint is on there now? If you rub your fingers across it does it come off or stay on?
This will matter.
Good Luck!
supersoaker548
Re: bottom paint
to help ya get started try a search here and in the Boat Restoration, Building, and Hull Repair lot's of good info in here
and will need some more info.
salt / fresh water
stay in water or trailer
what paint is on it now
Re: bottom paint
The bottom paint on it now is the marine blue standard bottom paint, leaves a white film on your fingers when you rub it, kind of chalky, its a full time lake boat, just purchased the boat and would prefer it to be a black and more sleek/glossy
sasto
Re: bottom paint
Problem is...there is no standard paint. Two common types are either ablative or hard (keeping this simple). Appears to be ablative.
This is important to know what "type" of paint we have here to proceed with a recommendation on your selection.
Good Luck!
Chris1956
Re: bottom paint
You only need antifouling paint if the lake will grow slime. It would be best to check with other boaters who use the lake. If no slime, you can go back with two part polyurethane or an epoxy paint. This solution requires the boat be stripped to bare gelcoat.
if you need or prefer antifouling paint, powerwash what you have and roll some new paint over it. Prime any bare spots with a marine primer. Standard ablative paint is a bit better than std AF paint, and will work fine. There are some hard AF paints, that take special prep.
