Bottom Painting on a trailer
flwestcoastboater
So, I am going to paint the bottom of my boat. I was wondering... Is there any method or way of jacking up the boat to paint the parts that are covered by the trailer? It would just be a shame if i cant paint the whole bottom.
tashasdaddy
Re: Bottom Painting on a trailer
Getting Boat Off Trailer
you don't need stands.
1/you can lower the tongue to the ground. i would get some 6x6 or old railroad crossties cut the +- 12 inches, now block up the transom. 2/
Raise the tongue of the trailer the back of trailer will drop away from trailer. this is the tricky part. between the cross braces of the trailer block the keel lower trailer, boat will be suspended on the blocks.
3/ pull forward, lift bow again, and reblock i a different place. repeat until trailer is out from under the boat.
4/ to reload, just reverse the procedure.
if you were just working on the bunks, or painting the bottom. you could just do the first 2 steps.
