Re: Bottom Paints
Dmark, Do you even need bottom paint? Sometimes in fresh and brackish water there is no marine growth to worry about. You should check with the marina. BTW, you only need to worry about bottom paint for the place you keep the boat. Those trips to the ocean will have no effect, unless you stay 2 weeks or more.
If you need bottom paint, roll on two coats of West Marine or BoatUS Ablative paint. These are made by the Interlux or Pettit, but cost a bit less, and last multi years. Tape the waterline with masking tape, and use a brush to get a clean paint edge. Use disposable (cheep) rollers and tray liners, and use a power mixer for your drill, to mix the paint. The marine store should give you a good idea on how much paint you will need. (I think 2-3 gal, but it's just a guess, you can return unused gallons, and save the rest for next year's touch up of trim tabs, keel and other areas.)
