I need to replace the bottom yoke of the swivel bracket that attaches to the motor. It is a U-shaped piece w/ 2 hex bolts that go to the bottom of the mid-unit. Problem is the shift shaft runs through it, so removing the lower unit doesn't give me access to it. Can this be done by removing the mid-section. Does this require any new gaskets or special techniques. I've never had a need to remove the mid-section before.
Motor is 1989 Mariner 75hp 3cyl OC170850....Thanks in advance. This was asked a few times a couple of years ago, but answers were never given.
