NicoPags
- Joined
- Mar 24, 2014
- 217
Ok looking for some verification to my diagram here.
Bought a 1978 Evinrude 35HP Model# 35853R w. electric start.
The motor has 2 wiring harness? that connect together, then connect to corresponding posts into the ignition key switch. The guy I bought it off of used to just had a push button switch wired in as the 2nd wiring harness was missing. Id like to do it right and wire in they key switch beside the steering wheel and Gear/Gas handle control. The 2nd wiring harness seems to now be obsolete or unavailable so I will be making my own. I have purchased a Sierra MP39760 Off-Run-Start, Push to Choke, key switch (listed as aftermarket OEM replacement). I will attach a diagram which I think is the wiring from various sources via iboats forum. The center most post was labeled for Choke, however it is a manual choke. So I was not going to wire anything into that post.
