bought wrong oil
crazy charlie
I mentioned to my bride that her Jeep was due for an oil change and I planned on doing it myself.She knows that we only use synthetic oil in her Jeep so she thought she would be a sweetie and pick it up for me.Well, she got the wrong oil.I know all I need to know about the oils that I use in my boats and vehicles,but I know nothing about what she brought home.Synthetic(at least she was listening)Rotella 5w40.For diesels I suppose.I will be returning it for Mobil 1 but I am sure plenty of guys would give it a whirl.How bad can it be????Charlie
Drowned Rat
Re: bought wrong oil
Exactly. :D <br /><br />That's what I use in my motorcycle, Mobile 1 version. It's not really any "thicker" than the 5W30.
imported_bjs
its good oil i worked for a shop one time the owner put in everything he owned even gas motors.i never seen any bad motors come out with that oil.
LubeDude
Go ahead and try it, if its the 4 liter engine, you might like it, its a great oil. (Of course you knew I would say that). Unless its like 0 degrees where you are 4 liters like a 40 weight.
crazy charlie
LD ,I may try it on something else but there is only 13k on it and it is a 4.0L.I dont want to experiment while under warranty.
JB
Non-boating Tech.
ZmOz
Originally posted by crazy charlie:<br /> LD ,I may try it on something else but there is only 13k on it and it is a 4.0L.I dont want to experiment while under warranty.
40 weight is a much better choice for that engine. It's not experimenting, it is tried and true. I've seen many oil analysis results that prove it is true. It used to be the factory recommended weight until the EPA stuck their noses in it.
crazy charlie
So the general opinion is that Rotella synthetic 5w40 would be fine for applications other than diesel.
BoatBuoy
In times past, diesel oil had more detergent properties. What I was told, diesels are less forgiving of deposits.
surlyjoe
yes more detergents is the main difference, it can actually make your motor too clean.
crazy charlie
This has got to be the first post re; oil that there have been ZERO disagreements.There is a first time for everything... ;)
LubeDude
Originally posted by theScrumbler:<br /> yes more detergents is the main difference, it can actually make your motor too clean.
What????? :eek: :eek: <br /><br />Maybe if the engine was an old engine and had a lot of deposits already, but we are talking about an almost new engine.<br /><br />What weight oil does you owners manual require?
crazy charlie
manual states 10-30 for temps 0 to 100+ degrees and 5-30 for below 0 to 100
