billfisherman
- Joined
- Aug 26, 2011
- 2
I purchased a 2000 Javelin Venom180 fish'n ski a few years back and have had a heck of a time tying to solve a problem. The boat is in excellant shape and has a 150 Johnson. When I'm up on plane and start to trim it out, the boat starts porpising to the point you have to trim it all the way down and then try again. If lucky, I could use a moderate amount of trim (1/4 way) before it would start again. The second problem is once on plane, it would lean quite a bit to one side or the other, rarely wanting to run level and this is not affected by load distribution in the boat. I installed a jack plate, tried different heights, tried 3 and 4 blade props but nothing seems to work. I finally installed a hydrofoil and this took care of the porposing, but not the severe leaning. Ive owned several boats (including 3 othe bassboats) over the years and I can't seem to get this one to work properly. Any help would be appreciated.
