Put the muffs on and fired her up. Ran perfectly, except I noticed the tach would read out as if the RPM was increasing when it wasn't. Then it would bounce around on its way back down to the correct (lower/accurate) reading and be fine. Then every so often it would repeat the same pattern. Sometimes it seemed to be corrected by a left middle finger knuckle wrap. HELP.
