thisusernamevalid
- Joined
- Sep 8, 2012
- 16
Hi. I just picked up a 15' aluminum boat. The bow eye is an old rusty eye bolt with a couple of nuts. It's loose and the original mounting hole has become enlarged.
I want to replace with a proper single shank bow eye. It seems there sould be some sort of spacer or filler behind the hull to spread out the contact area and provide a flat land for the nut and washer. Looked around on the net and can't find anything.
I was thinking about using some JB Stick to fill the oversized opening and create a wedge filler inside. Then, tighten down the nut and washer until it seats flat, let the JB cure, then tighten again.
Another thought was to use a piece of wolmanized wood to make a filler.
Any thoughts? Is there a product out there I'm missing?
Thanks.
Thanks.
