bow lift, as a fuction of the prop pitch?
31scorpion
Hey Hey Quick question<br />31 foot boat, I have 23 pitch mirages counter rotating, boat at high speed seems to "lay flat" and shifts side to side, but not tilting back and forth, flat side to side in the transom like on ice.(above 50mph) Q: If I lower the prop pitch does that alone, provide the engines more leverage to trim the boat to a desired angle (bow up)? any other suggestions.....of course thanks for the help!
Re: bow lift, as a fuction of the prop pitch?
Pitch, as a function has little to do with Bow-Rise..........<br />That's done with Blade Style.......<br />Round-eared Blades, with Longer Rake will provide Bowlift.....<br /><br />I'm not sure Where the mirages fit in......
Winger Ed.
Sounds like 'chine walk'. From what I've heard, its just inherant in some boats. What makes them handle & ride well at one speed-- slow and medium for example often makes them a bit squirrely at high speed.<br /><br />As far as the tilt, if you've got full inboards, about all you can do is transfer weight around to change the bow angle. Trim tabs will force the bow down, but they won't make it come up any more than it already can. If you've got outboards or inboard/outdrives- just raise the angle of them a little at a time to bring the bow up.<br /><br /><br />Lowering the prop pitch will let it come out of the hole and accelerate faster, but then again it will also probably let the engines overspeed for a reduced speed on the top end. (the same effect as putting smaller or shorter tires on a car.)<br /><br />If its getting up that fast, and doesn't leave much of a wake, its probably set pretty close to perfect unless you've added a bunch of weight to the front.
