Bow light not working
brodmann
All a switch does is make contact between the two wires. It basically makes the two wires touch each other.
nola mike
Chieftain, you go to any switch in your house (not a 3-way) and reverse the wires on the switch. It will still work!! A simple switch has no positive or negative. The screws aren't different colors are they. You can run hot straight to a light and put the switch in the return, or ground, or neutral wire and it completes the circuit when turned on. Or, you can run power to the switch first and then to the light or whatever fixture it goes to and you can still wire it either way and it still works. Don't you guys remember middle school science class where you learned about a simple circuit? The "switch" was a simple piece of metal that made contact to complete a circuit. That hasn't changed. Go ahead and change the wires at the switch. Those wires aren't positive and negative!! They are either the power going to the light and the current passes through the switch when on, or they are the negative or ground wires that complete the circuit to ground when turned on. Think about this just a little guys. A switch has not positive or negative unless the switch is a lighted switch that lights up when it's turned on. If that's the case, then yes, he may have the switch wired incorrectly. But simply changing the light fixture will never require changing the wires on the switch. Go ahead, change the wires on the switch. Still, current will pass through when on and not pass through when off.
You're correct. Sounds like a short to power, but I can't think of why flipping the switch would turn the light off if that's the case.
your old light was most likel
Because the switch is wired wrong
tpenfield
I'm thinking it may be a SPDT switch and the wires are backwards. . . or the switch itself is upside down.
Won't really know until we get a bit more info about the switch (pictures of switch . . . front & back)
nola mike
Can't wire a SPST switch wrong, which is what I was ASSuming. Switch CAN be installed reversed though, like @tpenfield said.
Without having moved the switch, a SPDT with the wire on the wrong output sounds the most likely...
However, @rjmman , you said you didn't touch the switch or wiring under the dash?
That's what I get for posting after my bedtime.
capecodtodd
If the new light is a LED then it could have a diode in it and having the wires right is essential.
1975oday22
Wouldn't cause the behavior described if wired backwards regardless.
try it. ive done it many times. thinking i was on the right wire. i had to learn the hard way tho. this is why both scott and i said to switch the wires at the switch. or when installed he didnt put the right wire from the switch to the light. and reversed the on off function. plain and simple . yes it happens.
nola mike
Nope. Not unless it was not a simple on/off SPST switch. The LED can have polarity that an incandescent doesn't, but it won't magically cause power to reach the light that otherwise wouldn't because of an open switch. If anything the light wouldn't work at all. Post a wiring diagram of how to miswire a SPST switch, or anything showing that the polarity of the switch matters. Or post a diagram that would result in the behavior OP describes.
tpenfield
Unless we get some more info from the OP ( @rjmman ) it is all speculation.
I am holding out for a SPDT switch with the wire reversed . . . :D
capecodtodd
No? If the power is going through the switch out to the light it could be stopped by a diode. I have experienced this when installing LED lights in my model trains.
Those things can be tricky.
nola mike
No. it could be stopped by a diode if installed backwards (= no lights), but it couldn't magically apply power to the circuit if the switch was open. Lights wouldn't work at all.
brodmann
Thanks for backing me up guys. I was the lone ranger there for a while. It could also be a lighted switch wired incorrectly. A switch that has a light that comes on when the switch is turned on basically has 2 circuits and at least 3 wires. Hot, ground and load (power to the light in this case) and sometimes an additional ground for the load. But yes, we need more information from the OP. I hope our "discussion" on reversing wires on the switch didn't chase him away.
