bow pulpit help?
Terrulle
I'm looking for a bow pulpit for a '95, 27' Grady Sailfish or similar. There has to be someone out there that could lead me in the direction of "something" I can use to replace the one I have which was damaged in the past hurricanes. The one I have is not repairable. It was snapped in half. Any help will be appreciated. Thanks again. T.
dmarkvid2
Re: bow pulpit help?
How is it attached? Is it wood or fiberglass? any pictures? Also, there must be alot of Marine Salvage Companys down there in Fla. I would check them out first. They might have some.
Terrulle
Mark, It is bolted to the bow. It has been laid up in a mold at the factory. It's made of fiberglass with a foam core. I'll try to get some photos. Also I've been to several surplus yards but to no avail... I have found after market pulpits that I could "make" work, but I'm trying to keep everything original. Thank you for responding. I'm just hoping that the right person sees this. Doesn't hurt.....
dmarkvid2
Well I guess you answered your own question. If you want to keep it all original, you'll just have to buy one new from the MFG. or keep searching. Of course, if you're handy you could make one out of Teak wood, that might look good. Good Luck
