Re: Bowrider Towing
....may be marginal but with the center section closed, down force will help reduce any lift by the bow at interstate speed.
On the other hand, with the center section open your chances of a rock chip are reduced by about a third.
it will increase lift, same as the cabin of a car causes lift. Think of the shape of a wing, faster air moving over the top, slower air under. By closing the windshield you get a nice wing shape with high speed air moving over the top of the boat.
Spoilers only work to increase downforce when the low pressure area they create isn't directly above your
entire vehicle. (there is an exception... dragsters that have spoilers on the front. They create a low pressure area immediately behind the spoiler, but also a very high pressure area a little further back when that mass of air collapses back down. Net gain in downforce)
anyway, as far as this is concerned, won't make any difference. That is what the winch and safety chain is for! Personally I tow with it closed and locked. Less chance of it getting ripped off by a gust from a semi.
