Re: Box Anchor?
I just went through the anchor plight myself. I have a heavy 22' walkaround, and boat in mostly sandy areas, up to about 60'. My wife (108lbs) handles the anchor at least half the time, so weight was a huge deciding factor.
I looked at the box anchor, and for the money, short history, and weight, I went against it. For your boat, the Small box anchor is pushing the upper limit, and the large box anchor would be my choice. The weights are 19 and 25 lbs. respectively. That's a heavy anchor. $150 and $180 is a chunk of change, too.
My 3rd choice was the traditional claw anchor;
But I don't have a pulpit or anchor roller, so I was concerned about storage. Weight on these are about average, and for your boat, the 14lb would be the correct one. Price is about $130 (Delta Fast Set galvanized). I think this would be a good choice, but you still need to add chain (about 6' is recommended in most instances (more never hurts)), so you have to think about your back.
My 2nd choice was a sea-claw:
The huge benefit to this anchor is no chain is needed. I'm on other forums, and everyone that uses this anchor (except for one guy) uses it with no chain. It's available in galvanized and aluminum. I was going to get the 12lb aluminum (7lb actual weight) for $99, and they have the bronze 12lb (actual weight 12lb) for $150. Everything I've heard about this anchor is great, so I was ready to order (didn't helo that shipping was free in FL) until...
I ended up getting the Fortress FX-11.
It's a traditional style fluke anchor, but is made of aluminum. Weighs 7lbs. It does need chain, but the wife is already used to the 6' chain plus the 15lb turd we were using. The feedback I've gotten from almost everyone is the same as their catch-phrase of the best anchor in the world. Holds in all types of bottoms. The msrp on the FX-11 is about $170, but I got crazy lucky on ebay and got one for $81. There is also the FX-7 (4lb) that would technically be okay for your size boat (and mine), but I figured if I can get the power of the larger one with the weight savings, I'm ahead of the game. Fortress can be disassembled for storage if needed, and comes with a lifetime guarantee on all parts (free replacement of damaged parts).
If I hadn't grabbed the one on ebay so cheap, I would have gotten the SeaClaw. I think the SeaClaw and Fortress offer the same benefits for equal money. I think I just like the look of the SeaClaw.
As far as the box goes, I think the weight will be your biggest issue. I also don't want to have to assemble an anchor in an emergency before I can use it, however 'simple' the assembly process is.
My 2 cents, and worth half that!
