No Title
I have an SD470 Sinistre1
Even if I put wheels on it I'm not rolling the thing anywhere. Two people cannot move it either with the side handles. I trailered my boat. I own a Jeep that can tow 7000lbs but honestly almost anything can tow a trailered inflatable. I've seen videos of a Prius towing an inflatable. The trailer in the photo I picked up for 150$, sanded and repainted, put new galvenized hardware on, tires and bunks.
Still alot of work to do, I just got the motor running nicely -
https://www.youtube.com/watch?v=7t4CpTYzIW8 -- but will probably have to eventually upgrade that, it was hard to pass up an 8hp mercury 2stroke for 400$ completely clean.
You're right though the floor is intense. I took a few trips on my Sea Eagle 9 with a friend and it honestly sucked. Marine plywood no keel. You could stand on it but without that support from the keel, it was like putting a piece of plywood over a waterbed. That meant constant sitting which turns into fatigue when fishing quickly. I thought about going with a 12-13 foot for two people, but I'm going to be in unprotected water quite a bit and want to be able to handle that confidently.
I'm getting it all setup for salmon fishing at the moment, waiting on my NRS frame to come, those things are really what turn this from a raft into a fully functioning fishing rig. Going to mount a cooler and some higher up seating in the front, along with thigh rails for bracing yourself. That'll let me get rid of the aluminum benches too and give me room for my Lowrance, as well as a support brace for a downrigger.
Let me know how the boat does, the 365 was the other one I was looking at.
