brake bleeding question please
Cruzomatic
I know I should know this, but on disk brake calipers and when bleeding the brakes, do both bleeders have to be opened or will opening just one of them do the trick?
Thanks.
CoffeeHound
Re: brake bleeding question please
To both parts of your question THE anser is NO !!
you bleed the on farthest from the master cylinder first - then bleed the next one farthest from the master cylinder, untill you get all of them bled !!
Cruzomatic
So each caliper has two bleeders on them. I only need to open one of them per wheel/caliper?
Thalasso
If the caliper has two bleeders on it, you open the one on top to bleed.
Mi duckdown
There are not two bleeders per caliper. just one per caliper. But Yes bleed the cal furthest then the other one.
Got Pics? Never have seen two bleeders Per Calipers.????
Thalasso
Post #3 gives me the impression there are two on each caliper.
Ayuh,... Those are multi-fit calipers, just bleed from the highest bleeder screw...
Air rises...
Treker57
Dual piston calipers will sometimes have 2 bleeders, one for each piston
Cruzomatic
Yea, from what I've read they are dual piston. I figured one per piston maybe. Ok, so I just have to bleed one of them and the one that is more to the top than the other. Ok....I think I got it....thanks.
Ayuh,.... In the link above, that's a single piston caliper...
CoffeeHound
That brake assy. in link is universal ( can be mounted to rear or front or on top of rotor ) depending on the installer !
Had OP mounted to the front or rear of the rotor instead of top ,,there would have been one bleeder valve on top per link Picture !!
Have almost same set & very happy with them .
Cruzomatic
oh, I see. Ok guy, thanks for the help.
bruceb58
If it were me, I would be bleeding both of them just to make sure.
