Brake Fluid Compatibility
four winns 214
I just overhauled the brakes on the trailer for my 1984 Sea Ray cuddy. I used synthetic DOT 3 to refill. I also have a 2002 Four Winns trailer and I am unsure whether it has synthetic or regular DOT 3 fluid. I looked on the label of the synthetic DOT 3 fluid and did not see any restrictions about mixing it with regular DOT 3. Anybody know whether the two can be safely mixed?
bruceb58
Re: Brake Fluid Compatibility
Yes they can. My Valvoline synthetic brake fluid states this right on the front of the bottle.
If you re did your brakes, I would just flush out all the old anyway. I change mine out every couple years.
kenmyfam
Agree with Bruce, bleed it out and replace.
tawood
You can even up it to synthetic dot 4 without harm. Dot 4 is just a better boil level. Again, I agree with the others, I would bleed it all and replace though.
four winns 214
Thanks guys. The Sea Ray brake re-do was a complete fluid replacement. The reason I posed the question is that I'm going to keep a bottle of brake fluid in my "tow box" just in case. And when it comes time for the Four Winns trailer brakes, I will replace its fluid, too.
