76SeaRay
- Joined
- Aug 24, 2017
- 1,071
I bought my boat and trailer in Colorado and moved it to Washington so I rebuilt the surge controller, replaced the rusted out brakes and replaced the rusted out brake lines (actually rusted through) before towing. I decided to go with the coated brake lines to prevent future corrosion. It was a pain to flare the lines with the coating. At the time I had to change them with the boat on the trailer by crawling underneath so that could have led to problems with flaring. Anyway, everything was fine on the drive from Colorado to Washington but shortly after I got here I had a brake line flare start leaking at the wheel. I will be pulling the trailer from under the boat in the next few weeks for repaint. Should I get rid of the coated brake lines and go back to steel or is there a special tool (other than the usual flare tool) for the coated lines that I need to make the flares reliable? Thanks...
