We just bought the boat on Friday. Dropped it in the water today.
I read in the manual that the best way to break it in is to run it at lower RPMs 90% of the time and then WOT 10% of the time for at least 2 hours. No problem.
We kicked off at 2pm and would run the throttle at half speed/rpm for 9 minutes, then open it up for 1 minute, then slow down and repeat.
We were having a great time and had been out for about 3 hours when all of a sudden the motor started stalling/sputtering and losing power. With the throttle pushed forward it felt like the motor was going into neutral. I turned off the ignition and we checked the fuel. It looked like it was a little low (I had just put 20 gallons in that morning) but not too low. I started the engine and it beeped for a couple of seconds. I accelerated and we went about 100 feet and it sputtered again and lost power. Turned off, waited a few minutes, same result.
We got towed to the nearest marina and filled it up with gas, only took 6 gallons. Started the engine, heard the beep, went 100 feet, sputtered/stalled out again.
So every time we turn it off and turn it back on we can run normally for about 20 seconds then we lose power.
I think it is something simple, but I don't know what it is. That beep could be a number of different things, according to the manual.
I'm taking it to the dealer Tuesday and having them fix it. Shouldn't cost me anything since the boat is 2 days old. But I would like to know if any of you know what this could be since I suspect it isn't anything major.
