Hey all!!
Recently picked up a 1994 Chaparral on the cheap. I knew it had a few issues but the drive was not one I was worried about. When I purchased it I ran the motor and it shifted into forward and neutral fine. It however was a chore getting it into reverse.
So I automatically think its a shift cable binding up which is no big deal. I get the thing home and start to inspect finding that after I remove the drive from the boat the shift cable seems fine.
I then pull the back cap to check out the inside of the upper. Everything seems okay. I find that once again its really hard to shift by hand. I can do it while turning the input shaft but its tough. What I find even more strange is the input shaft seems the hardest to turn when its in neutral.
So next I pull the entire top end apart to inspect. I pull the cone clutch and gears all apart to see if something seems out of whack. Nothing seems wrong that I can see. The only thing I can see that I find odd is its pretty hard to push both gears together. I assumed it would be a fairly smooth process however it was pretty tough. Its almost like the springs inside bind up until all of a sudden they pop into place. Not sure if this is normal.
So lastly I split the top end from the bottom to eliminate the bottom being the cause (of this issue). I still have the same issue with it being extremely hard to get into gear.
Any bravo mechanics out there who can chime in.
Thanks
Thanks
