Elk Chaser
- Joined
- Jul 29, 2003
- 186
The gear oil reservoir leaks constantly, I've taken it apart and check the plastic bottle and it looked fine. I checked the o-ring at the bottom and even added a little non hardening gasket sealer for good measure. I removed the plastic hose clamp and replaced that with a stainless worm gear. The cap is tight every time I check it.<br /><br />I've read where the Bravo 1 can heat up and over fill the reservoir so I custom built a dual pick up drive shower out of 1/2" stainless tubing and have checked the reservoir while running high speed. It was not anywhere near the top. <br /><br />The oil comes out of this thing and makes a mess from all the jarring around in the water so I cannot tell exactly where it is coming from.
<br /><br />This has been driving me crazy and makes no sense. I'm nearly ready to buy a new one but darn it, that leak has got to be fixable.
<br /><br />Anyone else seen this problem and know the fix?
