Re: Bravo 1 water connection
A manifold that, what, envelopes the water intake?
At $100 for the Bravo muff (w/o side intakes), I think the drive submerged in a large pool of water will work well, especially since I already have the tub. I will probably just keep it in neutral as I've read the prop rotation will quickly blow most of the water out of a tub...even a 60 gallon tub. I also read that unless you have a high pressure hose, the muffs allow very lttle water into the inlets, and then through the system, so you are kind of confined to idling or just above with muffs.
See any problems with my 60 gallon pool, provided that the water supply stays on, of course?
