I know it's hard to diagnose a noise without hearing it but I'll ask anyway. I have a noise that seems to be coming from the outdrive that started shortly before haul out. It's kind of a rattling, clanging type noise at low rpm (700 - 1500). It does not change when I turn hard in either direction. I pull the drive every year for inspection and put maybe 35 hours a year on it. I change the lube every fall with the recommended quicksilver high performance lube and it looks like new when I drain it. I always drain it into a very clean pan so I can check for metal shavings and have never found anything in the old oil.
I read where a gimbal bearing noise would be effected with a hard turn and like I said I don't hear any difference going straight or turning. Any help would be appreciated
