johnrmclean
- Joined
- Jun 12, 2007
- 82
Seeking repair advice.
I seem to have developed a small intermittent leak , usually when I use the trim. Oil appears to drip from the brass connector that protrudes thru the hull and connects on the outside to the feed line that runs thru the gimbal and bell housing. I believe the connector is a nylon hose clamp part number 54-415825 which is no longer available and has no recommended replacement.
Can this be serviced by either tightening or replacing the clamp without removing the outdrive?
