skunkedskippy
- Joined
- Apr 30, 2017
- 130
Trying to remove my bravo outdrive. I removed the the trim cylinders and the 6 nuts. Put a block of wood on top and pulled up on the outdrive but it won't break free. Sprayed some wd40 around the studs and between the mating surfaces but it still won't budge. Any other tips or tricks to this?
I also broke off the head of the torx screw that holds the middle port side washer. What does that do and do I absolutely need to extract it and put a new screw in?
