Re: bravo 2 outdrive
It really depends on what was done during winterization. During winterizing, the gear lube gets changed, and the drive should be pulled to inpect for water in the bellows, check the alignment and to lube the ujoints, gimbal bearing, pull the prop and lube the prop shaft. Now, if that wasn't done, you better do it now. Cause if you had water in it, you may really have problems now.
