MightyEsquilax
- Joined
- Jul 15, 2012
- 32
Ok, I have great results to share on my Bravo 3 cone clutch reconditioning and a follow up question for the experts. First a brief (or perhaps long) history...
Last season my Bravo 3 was starting to delay grabbing into forward gear especially when the drive was warm after planing. When the drive cooled down after you were off plane for a few minutes the shift would grab much better. It was only noticeable in the forward gear. I learned a lot of lessons while diagnosing this to be a cone clutch and one of them was don't put cheap Walmart marine gear oil in because it is crap and boils whereas the High Performance Quicksilver SAE 90 does not boil and expand. In the off-season I tore down the upper gear housing and "buffed" the cone clutch with some 130 grit emery cloth per a recommendation I read. I flipped the cone clutch over (reverse side now the forward, etc...). I carefully replaced all the gaskets I lined up the timing marks and torqued everything the best I could to the Merc specs. I also took the time readjust the lower shift cable to spec using the Bravo 3 cable tools and bell housing tools. I readjusted the shift control cable to spec and took out any backlash in the cable. I remounted the drive and now I have what I would characterize as "perfect" grab in forward and reverse gears even after extended planing. No delays, no grinding.
Here is the follow up question. In the OMC and Alpha Gen 2s I have owned in the past I would describe a very satisfying "gunk" noise when going into forward and reverse. My Bravo 3 now has that satisfying "gunk" noise when shifting into forward and reverse that I never had before. The boat dealer that sold me the Bravo 3 (paraphrased) said the Bravo 3s don't make noise going into gear.
So, I've fixed my problem but can anyone confirm (or deny) that I have created a problem by now having that "satisfying gunk" noise going into forward and reverse on my Bravo 3.
I don't think it's a problem but I value iBoats forum thoughts and opinions! A quick thank you to all the forum users for helping me get this problem diagnosed and fixed!
