Re: Bravo 3 latest and greatest updates
I am purchasing a 98 Sea Ray Sundancer with a 454 and bravo 3 drive. I know Bravo 3 where known for corrosion. I have read about checking the continuity wires and mercathode need to be tested. I was told they don't need the zinc on the prop shaft any more (is this true). I was also told it will corrode in a couple of years no matter what (don't really believe that). So this is why I ask whats the latest and greatest with Bravo 3 drives? Also anything i need to know about the 454?
Thanks
Howdy,
I have basically the same thing (97 model B3/454) in my 87 Four Winns. you might want do some research on the Bravo III .
Most of the corrosion issues were related to not setting up the MERCATHODE system properly....... According to the OEM Merc Service bulletin on this subject, There is a very specific process to set one up and in some unique cases, sometimes 2 separate MERCATHODE systems are needed .
My Bravo3 doesn't have a zinc on the propshaft but newer ones do I think. I don't know what year they were added.
I store mine in the garage and I do not operate in salt water. If you are going to store yours in salt or brackish water it's VERY important to get the anti-corrosion system set up right.
The 454 is a discontinued engine but there's nothing wrong with them.
I went from a single-prop King Cobra drive with nearly the same HP to the Bravo III. The difference (improvement) was nothing short of spectacular (the top speed was slightly less....3 mph)
Regards,
Rick
