Bravo 3 outdrive
HAV2FISH
Im looking at a boat with a 454 merc. w/ bravo 3 outdrive. Are the bravo 3 any good?
TilliamWe
Banned
Re: Bravo 3 outdrive
Yep, good drives, with corrosion issues.
You need to pull the props to see the worst damage, if any. Special prop wrenches/sockets needed to remove the props.
TilliamWe
Banned
While this drive was not leaking because of it, this is what you do NOT want to see on the rear bearing carrier:
26aftcab454
the six counter rotating blades grip the water well- really good hole shot-
HT32BSX115
By the way, that animated picture was created by my 15 year old daughter (she's 18 now)
She took 24 pictures and I moved the prop slightly for each one.
Then she used the "Gimp" to resize and animate the layers....
http://www.gimp.org/
wallerus
3 blades on the front prop and 3 on the aft prop. ;)
Well after a long day of burning brain cells at work I envisioned 6 actual propellers not the blades on the props. Odd cuase I have a V/P D/P and it just didn't register.
A mind is a terrible thing and mine's a waste.
HT32BSX115
Believe me, most of us are all right in there with you!!:D
26aftcab454
I believe its called a Brain Fart---
I suffer from CRS-Can't Remember S--t:D
