Bravo 3 prop shaft seal tools question
CamaroMan
Hi - gotta change the prop seals on bravo 3.. Seeing 3 bearing carrier tools,
91-805374: Installs and removes the bearing carrier on the Blackhawk drive units. Also, use with 91-805382T Bearing Retaining Tool to remove propeller shaft retainer nut in the Bravo Three drive units.
91-805374-1: Installs and removes the bearing carrier on the Bravo Three drive units.
91-805382T : Installs the bearing retainer on the Bravo Three drive units.
Which ones do I need, at minimum? All 3 or can I get by with less -
tx
