I have a 2000 Sea Ray with a 7.4l Mercruiser/Bravo 3 combination and recently I?ve developed a problem when I shift from neutral to forward, I have never experienced a problem when shifting into reverse. Sometimes the boat shifts perfectly, the next time there might be a couple seconds of lag and then yesterday, a few times, it wouldn?t shift at all. When this happened I put it into forward gear and got it to engage at around 1500 rpm, I never took it out until I maneuvered into my slip and then it went in and out of forward no problem. Very strange. The engine and outdrive were removed last December to replace the transom seal, boots, etc., possible something has worked it?s way out of adjustment since? Any suggestions as to where I should start troubleshooting?
Locke
Locke
