Bravo 3 Steering Actuator OM700
repair man
On the parts schematic it shows 2 fittings for the power steering hoses and it looks to me like they are quick disconnects. The boat I am working on doesn't have quick disconnect fittings. The part number I am finding for the steering actuator is 806034A1. Is that the correct part number?? Or am I looking at the fittings incorrectly? The drive serial number is an OM700.
HT32BSX115
Re: Bravo 3 Steering Actuator OM700
Howdy,
The newest model Mercruiser power steering systems have quick disconnect fittings. Older ones do not.
repair man
Ok thank you that is what i figured. But but with that part number 806034A1 the threads are the same for the quick disconnect fittings? And are the O- Rings the same on the schematic?
HT32BSX115
I can't say for sure. I suspect you could simply remove the fittings on the actuator and do it the the "old way" To be sure, you might give a call to a mercury dealer and ask them.
If your hoses are the least bit questionable, you could also replace the hoses and get them with the quick disconnects on them.
