Bravo 3 Thrust Washers Dont Fit New Lower Unit?
jws123
I just finished up painting and reassembling my bravo 3 after swapping out the lower unit with a good used non corroded one. When I went to put the props on I noticed the thrust washers didn't fit? the first one is to big/fits loose and the smaller one does not appear to go on all the way.. Props are quick silver 24P props. What ones do I need to get? they fit the old lower unit fine is there dif sizes or something?
Pics attached.
Take a pic a bit further away but not to far. Have both the thrust washers installed and not installed. I looking for perspective
The first pic isn't bad but would like to see same angle yet bit farther away. The second pic is not any good for me. My guess is one is older then the other, or more worn.
I'm not at home so don't have all my manuals to review.
jws123
Ik its hard to tell from pics here is few more i just took. I was trying to look up if there was dif sizes for dif years but I didn't get to far. I guess it could be worn but it would have to wear a lot to be this far off. I dont see any marks on the shaft either so idk.
Will need my computer to look closer,but right now I don't think the new carrier has been installed correctly
jws123
Uno now that you point that out it does look a bit off the shaft on the old one sticks out a few hairs more almost like someone didn't put the carrier all the way in on the new one or something.. guess I gotta order the tool for the carrier.
Also thanks for your help so far its my first bravo 3 drive I am use to alphas :D
jws123
Was the drive being used or just someone selling it
Bought the lower unit used off Craigslist from a guy that hauls boats paid $700 as mine was corroded/cracked besides this issue the thing is spotless no corrosion and feels fine otherwise.
jws123
Just got the tool but you know dam well the carrier is solid... and yes i know its reverse thread I been soaking it down with pb blaster probably wont do much but i really dont want to heat it much i dont want to crack the case. How do you guys break these things lose?
jws123
Ok i was able to get it off with a bigger breaker bar pic attached how much in and out and up and down play is there suppose to be on the shaft with carrier out? there is a fair amount at the moment trying to determine if maybe whoever had this open last maybe didn't tighten the inner nut or whatever you wanna call that?
I'm out of town so unable to get to manuals. But there should not be much play with the bearing but in place. My guess is it was pulled apart and not preloaded correctly.
Will be back tomorrow afternoon if another does not respond
jws123
Ok thanks i am also going to take a vid of it tomorrow so you can see exactly how much play there is something is def not right. I also noticed one of the carrier seals was not installed right. Both where faced inward if i recall from another post they both go diff directions like on my old lower unit.
If you have 2 seals, I would recommend using the new style seals which are a double seal, part numbers:
1 each Small inner seal 26-8M0033407 (replaces 2 each lip seals)
1 each Large outer seal 26-861694 (replaces 2 each lip seals)
Dimensions 3 - 3/8 OD, 2 - 1/2 ID, 13/16 wide
You need the manual, what year drive is yours?
jws123
At this point i think i am just going to drop it off somewhere i am also getting a manual.
