paulrfrancisco
- Joined
- Oct 25, 2004
- 341
Does anyione have a procedure for removing and then installing a Bravo 1 drive? I have my manuals in the boat and its all covered up right now...
Not this yearOriginally posted by rodbolt:<br /> wonder if DonS ever snapped off a speedo fitting![]()
Click on the chapter headings in the TOC. They are links to the chapters.Originally posted by hudman:<br /> when I click on that link, i Only get 14 pages of tables of contents- am I doing something wrong?<br />thaks
Interesting, the Bravo manual doen't show anything that I can find about that connector, is it accessable externally prior to slitting the drive off the gimbal, or only after separation like the shift cable?there is a quick disconnect fitting between the drive and the bellhousing
Thanks. I did know that, I just like paper and have two nice, big, fat, loose leaf binders stuffed full of manuals 11 and 17 now...Originally posted by Don S:<br /> Hudman<br />If you move your cursor that looks like this,over the index page, when you get to a link for the different sections, the cursor will change to a finger like this
just click that new link and another section will open.<br /><br />Mischief Managed<br />If you have Adobe Acrobat reader version 5.0 or newer, it has a save function that you can just save a copy of each section to your computer. Not necessary to print it all out. Then if you want to print a page, you can choose which page you want and print it.![]()
