onsiteservice
- Joined
- Jun 21, 2012
- 29
2001 Chaparral MCM 350 Mag Engine Ser# 0M029132, Drive Ser# 0M107260. Gear oil laying in the bottom of the boat, from what I can see it appears to be leaking back through the flywheel housing, the line and fitting are dry. I removed the drive and the input shaft bellow was completely full. A few questions,
1. The only place that I could see where drive oil could enter would be from the input shaft seal....I assume...but then again the first three letters of assume.
2. I removed the inspection cover from the top of the drive unit, assuming (again with the assuming) that the snap ring comes out, gear and needle bearing pull off (?) and there must be a snap ring holding the input gear on as well as another bearing. Then does the input shaft pull out? I did not see a snap ring on the outer side of the input shaft. Also on assembly does the top cover set the bearing pre-load on the top gear? If so, torque specs?
3. Could I be wrong and gear oil is entering another way?
I haven't ran into this before and thought I would ask rather than tear down something for no reason. I have looked through the site forum as well as the adult only sticky and couldn't really find what I was looking for.
Thanks in advance for the info!
