Bravo Knock
krisnowicki
I had a new to me knockish tick sound coming from the drive. I removed the drive and the sound stopped. So I know it is in the drive and not in the exhaust. \
Oil looks great no water or metal shavings. I removed the top cap and it looks awesome no missing teeth or damage. It does not change when I turn or trim the motor. How can I diagnose the knock.
2004 Bravo 1 drive
HT32BSX115
Re: Bravo Knock
Howdy,
Did the "knock" change with steering left/right or trimming up/down?
If it did, it could possibly be the U-joints and/or gimbal bearing or input bearing in the drive.
I think all these drives make some noise though and it may be "normal"..........
krisnowicki
Re: Bravo Knock
no change with the trim or steerage. could the drive start to fail with no signs in the oil....?
Don S
Re: Bravo Knock
With the drive on the boat and the engine idling, you need to use a mechanics stethoscope to determine where the knock is coming from. Upper, lower, bellhousing area. etc. It will narrow down the search considerably.
krisnowicki
Re: Bravo Knock
roger did that..... it is coming from the upper where it meets the bellhousing area. Almost like the u joint is hitting the bellows retainer sleeve. But i didnt think that was possbile
krisnowicki
Re: Bravo Knock
also shifting in and out of gear does not effect the knock
krisnowicki
Re: Bravo Knock
I am going to do the u joints tongiht... Are the u-joints for all bravos interchangable?
krisnowicki
Re: Bravo Knock
pulled the u joints.... the yoke from attached to the drive seems to be worn a bit. What would this rub? The bellows sleeve? Also, there is no rubber seal that goes around the ring nut?
krisnowicki
Re: Bravo Knock
was the coupler out of round causing a knock with the gimbal bearing
krisnowicki
Re: Bravo Knock
coupler was out of round and causing alot of wobble. Half of the coupler was dead on alignment.. The other half slammed the shaft into something I assume the gimbal because the o ring was flattened after an hour
fishaman
Re: Bravo Knock
That is exactly what I see on my Bravo 2:
- Gimbal bearing o-rings were flattened when I took out the drive (half-moon shape instead of round in cross section)
- Irregular knocking sound from gimbal area when at idle
I checked alignment when the outdrive was off, and it looks very good, coupler splines marked the greased end of the tool very uniformly on all sides. So... do I have a worn coupler that should be replaced? That was the first time I took the outdrive off after replacing the engine 2 years ago. With the previous engine, there was some knocking sound, but I do not remember any flattened o-rings on the shaft.
Will greatly appreciate any suggestions, thanks in advance!
Alex
