bravo magnum - convert to accept trim senders?
CamaroMan
What major parts do I need to convert TO trim senders? I have alot of the small parts (hinge pins etc)..
Gimbal ring? what else?
thanks~
CamaroMan
to - just clarifying because theres alot of talk about converting to the magnum solid pin setup- i would like to add trim senders to a magnum-
Could use a serial number to make sure, but the Magnum doesn't have trim senders. The later version called the HP assembly used a single 3 wire trim and switch. It was used with digital gauges.
Mine is the HP and I have the single sender and also installed the Digital to Analog Merc converter, but it still doesn't work.
This is my thread discussing it
https://forums.iboats.com/threads/hp-transom-assembly-sender.640342/
CamaroMan
well poking around seems there are knurled press inserts- unfortunately just not for the 5/8 in marine stainless.. that would have been a real easy conversion! Hole is a few fractions less than 7/8..
CamaroMan
only option i believe is to swap in a regular style gimbal ring-
