Took the boat out this weekend ran fine for a while. Second time out I was just leaving shore when I had a problem putting in gear. It went into gear with a pretty good jolt after that I only had reverse. I didn't hit anything & I was pretty much standing still when it happened.
Checked all cables inside & all looked OK. I then pulled the drive to see if the shift cable had come disconnected at the shift lever latch & that looked OK. With drive off shift cable seems to move fine.
I am assuming that the Cone clutch got wedged into one of the gears. In which case I will replace parts that are stuck or damaged
The drive is off the boat the top & front covers are off.
My question,.... If the drive is working properly, should rotating the cam raise & lower the clutch?
Boat info; 2002 Reinell, 350 Mag MPI, Bravo One
Thanks
Thanks
