I am replacing the water hose, bellows, and shift cable on my 1993 Bravo One. I couldn't figure out that you're supposed to unscrew the water hose insert to remove the water hose from the bell housing. I basically cut it out. Need to get a new insert now....<br /><br />How do you remove the water hose from the gibal housing? I removed the cover that has the hose goes to the water pump, and it almost feels like there is another insert? How are you really supposed to remove the insert on the bell hosing?
