Hi all. Been lurking for awhile and figured it was time to sign up..... then finially got around to uncovering boat last weekend(I know I'm waaaay late this year) My bravo drive won't go up using the trim switch. No motor noise, no "click", nothing. It goes up fine if I use the switch labeled "trailer up", and the trim switch works fine going down. the trim switch was new last season and worked fine. Is there a seperate fuse that could have blown or should I figure the trim switch has gone south
Thanks in advance.
Mark
Thanks in advance.
Mark
