I dont know what caused it except maybe old age ! the mains looked fine not loose, the rod bearings needles were blue like lack of oil ,,,?,,, im just temporarly trying out a 20 hp powerhead on it with the small excess fuel line from lower intake to side of top cylinder blocked off,, and run it about 50:1 maybe add 2 ounces extra oil to the six gallons and see what happens, i do know there are two types of piston setups one is blowback type and non blowback type, im using the non blowback type in the new build like the evinrude has. ive also been using the newer pennzoil oil blue in color. then after some running i'll swap the powerhead and put the 25 back on and disasemble the 20 and look at it and see if any bluing on bearings.
